I tried to change the font on Kyocera Rise with Font Installer, after it was complete it required to reboot but now its on boot loop. When i go to Android System Recovery the bottom says E:cannot load volume /misc! Any Help would be appreciated!
Printable View
do a factory reset
When i do a factory reset it Formats the /data and /cache but it still says E:Cannot load volume /misc. Still stuck on the bootloop.
Are you unrooted? If so, how old is the phone? If under warranty, just do an exchange.
