Results 1 to 3 of 3
- 11-14-2012, 11:28 PM
Thread Author #1
dealing with multiple contacts that share the same phone number
Just switched from a PalmPre+ and am still trying to learn about ICS on my Droid4 but ran into something I can not seem to find a solution for:
I have several conference call contacts that share the same access number and I keep their unique access ID as part of the contact name so that I can type it in when prompted (once the call connects and the contact name is still visible on the dialer pad).
e.g.
"Adam's conference call code 12345678"
Work 1-800-555-1212
"Betty's conference call code 87654321"
Work 1-800-555-1212
"Charlie's conference call code 54637281"
Work 1-800-555-1212
however when manually choosing to dial from Betty's contact list, the android dialer ends up showing "Adam's conference 12345678".
is there a way to "disable the phone# look up when picking from the contact" which ends up displaying the first contact name it encounters in the alphabetically sorted list?
Thanks for any pointers
maniakman - 11-15-2012, 01:29 AM #2
Re: dealing with multiple contacts that share the same phone number
How long do you have to wait before entering the code?
You could have the phone number be 1-XXX-XXX-XXXXpppppppp12345678 and that should be different enough - 11-26-2012, 02:48 PM #3
Can you use hotspot with lte and talk at the same time?
By zlee67 in forum Verizon Galaxy NexusReplies: 2Last Post: 02-09-2012, 06:53 PM -
Does the Thunderbolt share the same battery as....
By DreamSTi in forum Thunderbolt AccessoriesReplies: 5Last Post: 10-21-2011, 11:27 AM -
Tango not showing contacts that have the app
By Doc in forum Android ApplicationsReplies: 2Last Post: 01-21-2011, 02:48 PM -
Multiple Ringtones set at the same time for Notifications?
By benchwrmr22 in forum Sprint Epic 4GReplies: 0Last Post: 01-18-2011, 09:15 PM -
Is the Hero and the Eris the same phone?
By nbnguy98 in forum HTC HeroReplies: 14Last Post: 11-15-2009, 07:34 PM
Reply
