Android 4.0.4 - calendarcg.apk problems
Dear all,
i've a strange problem with my calendar apps.
If the phone is setting in english language , i can open the calendar, i can insert new event, i can edit event.
If i shift the phone in another language setting ( italian,french,german or other) i can open the calendar,
but when i try to insert a new event i receive follow alert : "The application Calendar (process.com.android.calendar) has stopped unexpectedly. Please try again."
and asked to force close.:(:(:(:(:(:(
I tried to reset the phone, hard rest the hone, clear data but nothing..always same problem.
Please can you help me to solve these problem??
Tnx,
Fabrizio
Re: Android 4.0.4 - calendarcg.apk problems
If a reset didn't fix the issue, then, it's a bug in the calendar and there isn't much you can do, short of getting a third party calendar app.
Tnx.i've decompiled the apk and i've modified more xml.
i suppose that i've to modify ANDROIDMANIFEST but i don't know how...can u help me?
Lol, no, sorry. I don't delve that heavy into Android. I'm already a programmer for my job, this is just supposed to be fun, lol.
Sent from my Transformer Prime TF201 using Android Central Forums
Lol :-)
i hope that i fan solve this problem with help of forum
I know we do have some rather tech savvy Android people here, so, hopefully someone can help you. :D
Sent from my DROID X2 using Android Central Forums
Tnx again Devinator :-)... i'm waiting and i try to find where is the bug. :-)
