Quick settings in 4.2 question
I just received the jb 4.2 ota today and just now had some real time to play around with it but I can't figure out how to pick which quick settings I want in the quick settings menu... Or are the ones that are shown the default ones that have to stay permanently?
Re: Quick settings in 4.2 question
I don't believe you can select which settings to display, at least not with stock.
Sent from my DROID RAZR using Android Central Forums
