Need help to Root Android 2.3.6 MTK6573 - 7 inch tablet phone
mvasu78
I bought a chinese tablet -Dolphin A70- 7 inch tablet phone Android 2.3.6 (CPU: MTK6573 ARM11 Dual core each 650MHz)
I need help to root this phone and also want to know whether i can upgrade this to ICS from 2.3.6?
Phone specs are below
OS: Google Android 2.3
RAM: 512M
Flash Memory: 8GB
Support TF card extend 16GB max
Display: 7 inch TFT LCD capacitive touch panel 800*480
Front Camera: 0.3 Mega Pixel
Rear Camera: 2.0 Mega Pixel
Battery: 4000mAh (Could be installed by yourself)
Networking: WiFi 802.11 b/g/n
GSM: 850/900 DCS: 1800 PCS: 1900
Can be used as a mobilephone
Below is the configuration when i saw "About Phone" in the Settings menu
Model-> e1107_v73_ht_84g
Androis version->2.3.6
Baseband version-> MAUI.11AMD.W11.37.SP.V17.F1,2012/03/14 16:54
kernel Version->2.6.35.7 (Sun Apr1 10:49:05 cst 2012)
Build number ->ALPS.GB.FDD2.MP.V4.5
Custom build version->133248561
Devinator
Sūpā Saiya-jin Fō
Jul 27, 2011
3,000
147
You are going to have to scour the internet for a root process for your tablet, and, a ROM for your tablet. The less mainstream the device is, the less likely you are going to find either.
Xopher
Trusted Member
Dec 21, 2010
428
38
28
You might want to check slatedroid.com. There are a lot of ROM developers for different platforms over there.
lucharmer
