1. mvasu78's Avatar
    I bought a chinese tablet -Dolphin A70- 7 inch tablet phone Android 2.3.6 (CPU: MTK6573 ARM11 Dual core each 650MHz)
    I need help to root this phone and also want to know whether i can upgrade this to ICS from 2.3.6?
    Phone specs are below
    OS: Google Android 2.3
    RAM: 512M
    Flash Memory: 8GB
    Support TF card extend 16GB max
    Display: 7 inch TFT LCD capacitive touch panel 800*480
    Front Camera: 0.3 Mega Pixel
    Rear Camera: 2.0 Mega Pixel
    Battery: 4000mAh (Could be installed by yourself)
    Networking: WiFi 802.11 b/g/n
    GSM: 850/900 DCS: 1800 PCS: 1900
    Can be used as a mobilephone
    Below is the configuration when i saw "About Phone" in the Settings menu
    Model-> e1107_v73_ht_84g
    Androis version->2.3.6
    Baseband version-> MAUI.11AMD.W11.37.SP.V17.F1,2012/03/14 16:54
    kernel Version->2.6.35.7 (Sun Apr1 10:49:05 cst 2012)
    Build number ->ALPS.GB.FDD2.MP.V4.5
    Custom build version->133248561
    11-16-2012 02:34 AM
  2. Devinator's Avatar
    You are going to have to scour the internet for a root process for your tablet, and, a ROM for your tablet. The less mainstream the device is, the less likely you are going to find either.
    11-16-2012 08:58 AM
  3. Xopher's Avatar
    You might want to check slatedroid.com. There are a lot of ROM developers for different platforms over there.
    11-17-2012 04:51 PM
  1. Need help to create Android img file
    By wondering2012 in forum General Help and How To
    Last Post: 04-14-2012, 04:38 PM
  2. New to android, need help with rooting please
    By Mike863 in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 12-15-2011, 12:52 PM
  3. Need help to Root Aria with Froyo 2.2
    By peeace in forum HTC Aria
    Last Post: 11-10-2011, 12:29 AM
  4. I need help to root my EVO3d
    By Milad6923 in forum HTC EVO 3D
    Last Post: 11-04-2011, 04:06 PM
  5. need help to root Nexian Journey
    By robotgedegijo in forum General Help and How To
    Last Post: 12-13-2010, 08:51 AM
