Results 1 to 7 of 7
    Default Syncing Bookmarks
    I am looking for a away to sync bookmarks between my work laptop and my GS3.
    Situation:
    -I cannot use Google Chrome on my laptop due to an conflict with Symantec. (The IT guy asked me to stop using the "-no--sandbox" work around)
    -I am using Firefox for my laptop browser.
    -I do not want to install Firefox on my phone.
    What is the simplest way so share bookmarks between my laptop and phone?
    thanks
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Syncing Bookmarks
    Did you go to Tools >> Set up sync in FF? I know it'll sync your tabs between PC and mobile device. Not sure if it does bookmarks too.
    On a side note: does anyone know a way to get around the Google Chrome - Symantec issue?
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by Devinator View Post
    Well?
    Sent from my Transformer Prime TF201 using Android Central Forums
  5. #5
    Quote Originally Posted by Jtitus187 View Post
    Install IE tab Chrome extension to use chrome just like IE. all web app is compatitble
    edit: seems like its antivirus causing the problem.
    Well?
    This will sync with Chrome on my mobile device?
    - - - Updated - - -
    Quote Originally Posted by still1 View Post
    I tried the IE tab Chrome extension... it made IE unusable.
  7. #7
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    No, it'll sync with FF on your mobile.
    Sent from my DROID X2 using Android Central Forums
  1. Sync Bookmarks?
    By VydorScope in forum ASUS EeePad Transformer
    Last Post: 06-02-2011, 08:47 PM
  2. Sync bookmarks from Safari to Nexus One?
    By mohd4325 in forum General Help and How To
    Last Post: 06-06-2010, 01:42 PM
  3. Syncing Bookmarks
    By ptb127 in forum General Help and How To
    Last Post: 05-27-2010, 09:22 AM
  4. Syncing Bookmarks
    By ptb127 in forum Verizon Droid Incredible
    Last Post: 04-30-2010, 07:24 AM
  5. Sync bookmarks from Safari to Android Web Browser?
    By mohd4325 in forum Google / HTC Nexus One
    Last Post: 01-25-2010, 01:24 AM
