My HTC Inspire has ability to send MMS over WIFI without using Cell data. Can newer HTC 's do this?
Hi,
I have an HTC Inspire from AT&T (almost 2 years old). One of the reasons I bought this phone is it's ability to send an MMS over WIFI so I don't use up any cell data (saves a lot of $/data) I am looking to by a newer HTC phone but it looks like they might have disabled this feature? The way it works is that the phone divides into 2 separate messages to send, and then they are merged back together before they get to the receiver as a MMS.
My phone was never "hacked" it was designed this way.
My Question is? Are there any AT&T phones (out of the box), that have an ability to send MMS over WIFI only?
Thanks for your help, Getmorehp
