hi folks.
got a notification that i had an OTA system update and it's showing this type of thing for the last three hours (text keeps changing)
is this part of the update? is it normal that it should take this long?
thanks for your help!
Printable View
hi folks.
It shouldn't take that long to update OTA. To be safe, just keep the device plugged in and give it more time. Hopefully it will update safely. Btw, which device are you using?
So that text is part of the update process then?
What do the numbers at the top refer to? It's at about 6 hours now!
Sent from my HTC One S using Android Central Forums
Something went wrong...not quite sure what but something did...Quote:
Originally Posted by rivum [Only registered and activated users can see links. Click Here To Register...]
Their is nothing wrong just a developer option is selectedQuote:
Its a developer option to show cpu usage , nothing with the otaQuote:
Originally Posted by srkmagnus [Only registered and activated users can see links. Click Here To Register...]
Ah, I must have hit that by mistake. I'll look into figuring out how to change that.
Thanks for your help! This is a truly awesome forum!
Ah, I saw the picture from my phone and didn't pay attention to what was posted. Thanks for jumping in and clearing things up :)Quote:
Originally Posted by mattatwar1 [Only registered and activated users can see links. Click Here To Register...]
@OP, definitely a great forum and many great people who jump in to help out. Be sure to hit the thanks button for them once in a while :).
