1. BillyU's Avatar
    Hi, I have a 7" "Freelander MID" tablet. It's a chinese Android 4.0.4 device of decent quality.
    I can't load any new software or even update Facebook.
    From "Settings/Storage, I read that only 13.44MB out of 503MB internal storage are available. Since only 411MB are used by applications, this already seems strange.
    If I look at Settings/Apps/All, on the bottom I read that I used 307MB of internal storage and I have 196MB free. This seems to be a more reasonable number, since all my Apps are loaded in USB storage and I suspect some problems at what,if it was Windows, I would call FAT.
    Can you recommend some maintenance program that I can use to clean Internal Memory?
    Thanks!
    11-17-2012 04:47 PM
  2. Xopher's Avatar
    Settings > Apps
    Check each app to see how much cache is being used by the app and clear the cache. Go into the web browser and clear the cache there as well.
    There are a lot of things in the OS that take up space (like the datadata partition) that don't show up in the reporting a space used.
    11-17-2012 05:40 PM
  3. BillyU's Avatar
    Clearing the cache fixed the problem. Thanks!
    11-18-2012 08:03 AM
  1. Galaxy 4G - Internal memory full
    By vishal1857 in forum T-Mobile Galaxy S 4G
    Last Post: 12-29-2012, 04:03 AM
  2. "SD card or device storage is full" but it is not...
    By BigGuyNH in forum Motorola Droid X2
    Last Post: 01-14-2012, 09:21 PM
  3. SD Card says its full but it's not....
    By SBRoss in forum General Help and How To
    Last Post: 09-08-2011, 07:09 PM
  4. Internal Memory Full
    By AQuinn19#AC in forum Motorola Droid 2
    Last Post: 03-29-2011, 07:03 PM
  5. I'm so close to returning my Droid! But it's not my fault!
    By cheechoz818 in forum Motorola Droid
    Last Post: 12-22-2009, 11:13 AM
