Hi, I hope someone can help. I looked for an answer everywhere, including Samsung tech support and SONY VAIO-PC tech support representatives.
In short.
I can pair easily with any home computer, but transferring a picture from Galaxy S3 to computer via bluetooth always fails. I Checked all the settings. Tried on 3 different machines. Sometimes while pairing, it installs bluetooth drivers for S3, sometimes it does not. If it does, it lets me send file from computer to S3, but not the other way around.
It all works good on iMac OS10.
Same problem is with my friend's HTC EVO we tried on two PC laptops at work. Pairing goes smooth, but no data transfer. The Best we got was once we were able to send a file (picture) to our phones, but sending a file from phone to computer always failed.
Machines we tried:
Sony Vaio F13 #1 Windows 7 pro 64bit. Paired OK - File Transfer fails
Sony Vaio F13 #2 Windows 7 pro 64bit. Paired OK - File Transfer fails
MacBook Pro 17" ( 2011) running bootcamp windows 7 pro 64bit Paired OK - File Transfer fails
iMac 21" (2011) OS10 Paired OK, File Transfer OK.
Obviously its a windows issue. Any help would be much appreciated.
Thanks
In short.
Machines we tried:
Thanks
