Results 1 to 9 of 9
Like Tree4Likes
  • 1 Post By Devinator
  • 1 Post By srkmagnus
  • 2 Post By piizzadude
    Question Phoned dropped in beer!
    A fried dropped his HTC Desire into a glass of beer. We got it out instantly and removed the sim, battery and sd card, then dried it. I think he put it in rice to dry it out. Now. It turns on and seems to work but won't read the SIM card. It can see it, but won't connect to the network. I cleaned the sim connector with isoprop alcohol.
    Any help gratefully received
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Phoned dropped in beer!
    Is it possible to put another SIM card in there to test to see if it works? Then you can determine if it's the SIM card or not.
    Also, I did the same thing when I was in college, lol.
    Thanked by:
    Johnly likes this.
  3. #3
    how long in the rice?
    In my experience, done this twice (not beer), I had to put it in a tupperware container closed with slightly warmed rice (microwave) for 2 days.
    Thanked by:
  4. #4
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    How was the beer? j/k.
    I'm with Devinator. Stick another SIM card in that bad boy and see if it works...if not, then its probably something with the hardware and I'd give it a few days before making a final determination...
    Thanked by:
    Devinator likes this.
  5. #5
    Thankfully I've yet to try the rice trick, but every time I've read up on it, it seems 48hrs is the bare minimum to have it sealed up in lots of uncooked rice. Gut feeling though is that beer is a very dirty/sticky substance (unlike dropping it in water) and frankly I think the device is done. You might get 6 months out of it before it starts acting up and/or dies completely. Hope there is a more positive outcome, although I wouldn't hold my breath.
    Hope this turns out better for your buddy though...
    Thanked by:
  6. #6
    Johnly's Avatar
    Posts
    ROM
    AOSP, & stock.
    Great advice given. I would use desiccant from a shipping store. It is like rice on roids. They use it to keep freight dry in ocean going containers.
    Thanked by:
  7. #7
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    At least it died a heroes death
    Sent from my X-Band Modem... TY Genesis
    Devinator and Phantomlynx like this.
  8. Thread Author  Thread Author    #8
    The odd thing is, it could find a different sim, but wouldn't register on the network.
  9. #9
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Phone is probably a lost cause at this point. Did it trigger the water sensors? If not, you can exchange it, just be sure to leave the beer part out. If so, you are probably SOL and I hope you have insurance.
  1. Replies: 7
    Last Post: 06-10-2012, 12:40 AM
  2. Epic Dropped in commode now no 3g or phone signal HELP!
    By Epic User in forum Introductions
    Last Post: 04-11-2012, 11:31 PM
  3. Replies: 6
    Last Post: 05-24-2011, 06:23 AM
  4. dropping in and out of 3G mode/normal on the Inc?
    By jasonvancouver in forum Verizon Droid Incredible
    Last Post: 06-01-2010, 10:56 AM
  5. Phone sideways in car mount
    By SpeedVX in forum Motorola Droid
    Last Post: 12-02-2009, 02:38 PM
