Results 1 to 4 of 4
- 11-20-2012, 01:38 AM
Thread Author #1
Suggest a phone - GSM
I've been wanting to jump ship from Virgin Mobile for a while now and I wanted opinions on phones. I want to stay prepaid and have unlimited texting and at least a gigabyte of data, so I decided that T-Mobile's $30 plan is the right way to go.
That being said, I'm on a budget and don't want to spend more than $200 on the phone. I don't mind buying used either. I would like the phone to fall into these specifications, if possible.
A screen size of 4" to 4.3"
Support (unofficial or official) for CM9 or CM10
And a screen resolution of at least 480 x 800
I thought I had found what I wanted in an unlocked Samsung Captivate, but apparently I would only be able to use 3G if T-Mobile has converted their 2G radio towers in my area, and I have no idea if they've even started doing that around here.
For now the only phone I know of that falls into these restrictions is the Nexus S. Anybody know of any others?
Thanks - 11-20-2012, 02:05 AM #2
- 11-21-2012, 11:28 PM
Thread Author #3
- 11-22-2012, 10:27 AM #4
Re: Suggest a phone - GSM
The Galaxy Nexus can be bought between $200-$250 on ebay. If you can swing that extra $50 that's the way to go. Plus you'll have official JB and plenty ROM support.
Unlocked phones GSM
By sam_soren84 in forum General Help and How ToReplies: 1Last Post: 08-19-2012, 03:55 PM -
Sprint rep suggests rooting phone OK
By kevincwelch in forum Epic 4G Rooting, ROMs, and HacksReplies: 21Last Post: 11-22-2011, 01:24 PM -
Need a phone suggestion
By thekarens in forum The Android Central LoungeReplies: 1Last Post: 07-08-2010, 03:11 PM -
Best Android GSM phone to date?
By zoltrix in forum The Android Central LoungeReplies: 11Last Post: 06-25-2010, 12:10 AM -
Dual-Mode Google Phone coming later! CDMA/GSM/HSPA capable!
By 6tr6tr in forum Google / HTC Nexus OneReplies: 6Last Post: 01-07-2010, 12:02 AM
Reply
