I just flashed to jelly bean 4.1.1 on my verizon GS3. I can't get wifi to stay connected. It continuously rotates between "Authenticating", and "Saved, Secured". Eventually it gives up and just says "Disconnected". Anybody else having that problem?
Printable View
Have you tried removing the connection and adding it back? Tried multiple networks?
I have tried deleting it and adding it back in. It connects, but won't stay connected. It's making me crazy.
Have you successfully connected to another network?
I have. It connects to other networks fine. My husband's GS3 connects to the same home router with no problem. His is stock Verizon and mine is rooted. 4.1.1
Sent from my SCH-I535 using Android Central Forums
If your router is using WPA2 try dropping back to WPA. Some Wi-Fi have issues with WPA2, Your new ROM may be one of them.
Could always remove the password completely for a quick test to see if that is the issue. Strange that it connects to other networks, and, another phone can connect to your network. Give the password thing a go.
