Results 1 to 7 of 7
- 11-20-2012, 08:00 AM
Thread Author #1
Problem with Wifi after ROM
I just flashed to jelly bean 4.1.1 on my verizon GS3. I can't get wifi to stay connected. It continuously rotates between "Authenticating", and "Saved, Secured". Eventually it gives up and just says "Disconnected". Anybody else having that problem?
- 11-21-2012, 08:05 AM #2
Re: Problem with Wifi after ROM
Have you tried removing the connection and adding it back? Tried multiple networks?
- 11-25-2012, 07:28 AM
Thread Author #3
I have tried deleting it and adding it back in. It connects, but won't stay connected. It's making me crazy.
- 11-25-2012, 10:10 AM #4
Have you successfully connected to another network?
- 11-25-2012, 10:46 AM
Thread Author #5
I have. It connects to other networks fine. My husband's GS3 connects to the same home router with no problem. His is stock Verizon and mine is rooted. 4.1.1
Sent from my SCH-I535 using Android Central Forums - 11-25-2012, 07:03 PM #6
If your router is using WPA2 try dropping back to WPA. Some Wi-Fi have issues with WPA2, Your new ROM may be one of them.
Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 11-26-2012, 05:56 PM #7
Could always remove the password completely for a quick test to see if that is the issue. Strange that it connects to other networks, and, another phone can connect to your network. Give the password thing a go.
Wifi Problems With IHO BackSide ROM
By androidalais in forum Optimus V Rooting, ROMs, and HacksReplies: 18Last Post: 06-29-2012, 08:07 AM -
Problems with contacts after switching ROMs?
By THRILLHO in forum Thunderbolt Rooting, ROMs, and HacksReplies: 10Last Post: 06-23-2011, 12:58 PM -
Problems with Mail after Update, still deletes off server even though uncheck!!
By dfine1966 in forum HTC EVO 4GReplies: 8Last Post: 07-01-2010, 12:52 PM -
Pandora playback problem with wifi
By jeffc in forum Android ApplicationsReplies: 0Last Post: 03-19-2010, 09:34 PM -
Text messaging problem with wifi on
By Anubis in forum HTC HeroReplies: 7Last Post: 10-23-2009, 04:18 PM
Reply
