View Poll Results: Will you buy this product for phone use?
Voters
8. You may not vote on this poll
  • Yeah! Great find!
    1 12.50%
  • Why didn't I think of that?
    1 12.50%
  • No, my phone doesn't get that dirty.
    6 75.00%
  1. AnAm85's Avatar
    Hello Android Central Members!
    I have a wonderful product I found that works PERFECT for cleaning out your charger ports, MicroHDMI ports, 3.5mm audio jacks, etc;
    This product is found on the toothpaste aisle in your local retail stores. It's made by GUM and its a tiny wire brush made for flossing hard to reach places in your mouth. Only MY use for this product has turned out to be a perfect brush/cleaner for my T-Mobile myTouch Slide!
    Here's some pictures of the product. Give me some feedback!
    07-15-2010 05:26 PM
  2. kd0axs's Avatar
    I think that could do more harm than good. The part the bristles attach to is metal, so you could short something out.
    07-15-2010 06:00 PM
  3. mvpilot172's Avatar
    Canned air does the trick, or the squeeze ball cleaners for cameras.
    07-15-2010 06:42 PM
  4. bclinger#IM's Avatar
    A slightly damp rag.
    07-16-2010 01:22 AM
  5. gmz73#AC's Avatar
    I use a very tiny soft bristle paintbrush to get the dust out of the sides of the phone. Arts and crafts aisle at Walmart...1.99.
    07-16-2010 06:50 AM
