noob question: Moving a ringtone mp3, can not write.
Hi, new to android. Trying to copy a ringtone mp3 into /system/media/audio/notifications, using Astro File Manager.
Fails to copy, seems like I do not have permissions to write.
What am I missing here, do I need to Root to do this?
When I moved the file down from Dropbox, I copied it to /storage/sdcard0/Ringtones. This is strange, since I dont have an SDcard on this phone (Droid DNA). I could write to this location, but couldnt see the mp3 thru the Sounds tab in preferences.
thanks
Re: noob question: Moving a ringtone mp3, can not write.
Are you rooted? Lol it should copy
Not rooted. I only seem to have access to sdcard directory structure and nothing else. R
Have you thought about rooting?
Sure, but that doesnt answer my question.
How do you add ringtones and then be able to see them in the Ringtones or Notifications menu?
I shouldn't need Root to add a mp3 file.
No but try downloading a file broswer from the Google store it'll give you access to the SD card
