Re: Installing new SD card
Quote:
Hey all I have a s3 rooted with a 4gb SD card installed and I just got a 32 GB class 10 for it. My question is I have my stock ROM backed up o my 4 gig what would be the safest way to transfer the trwp file from the old one to the new one. I'm a little worried I'll corrupt the file or lose it
my awesome nexus 7
Here it's easy, follow instructions below:
- Using a USB Cable connect your device to PC & "Copy" (Do Not Move it) the SD card to a new folder on your PC OR Shut off phone (or dismount SD card in settings) & Remove old 4GB card & put it in SD Adapter to PC
- Install new 32GB SD Card in the "Phone/device", go to settings, find the new 32GB SD & "Format it" using your "Phone"
- Reboot phone & check the new SDcard is being seen (around 30-31 GB ish)
- Connect phone/device via USB cable to PC and open that folder on PC
- Copy (Do Not Move!) old SD card from PC to new Folder on phone/device (Optional name it Stock_Rom or similar)
- Disconnect USB cables properly ie eject
- Reboot phone & check, it should be all set
I prefer the "reboots", "folders" & "proper USB Disconnect"
Also put the old 4GB card in a safe place, I would also "Copy it" again to the "PC" as a backup
Their are other ways but I find this the safest method for most all devices
Hope that helps.
Thanks that's what I was gonna do just wanted to double check
my awesome red Slll on CM10
It took about 15 min to copy to new folder then to new card does that sound about right
my awesome nexus 7
Those are often large files, so that seems about right. Did you keep a copy on the PC as a backup? You should have one copy on new sd card, one on the PC and maybe one on the old sd card if you left it there.
Yea I have the old card put away and still have the folder on the pc , can never have to many back ups thanks for all of you guys help:beer:
my awesome nexus 7
