1. eyestotheKING's Avatar
    Problem with a frozen facebook picture upload notification in my drop down notification/task bar and menu.
    I tried uploading a picture to facebook (from my phone pictures using the facebook app) the other day. The picture never uploaded and this progress bar has been stuck at 20% in both the notification bar and in the drop down menu and I don't know how to remove it or make it disappear.
    I've tried swiping it away, holding it down, force stopping the download manager in my app settings, cleared the internet, chrome, facebook app, facebook HTC, and a few other chaches, turning airplane mode on and off (to maybe stop the upload if it was uploading?) and turning my phone on and off. Nothing has worked.
    Ive attached a screenshot that might help show what Im trying to explain.
    What do you think? Thanks!
    Attached Thumbnails PROBLEM: notification/task bar and menu-android-problem.png
    11-23-2012 01:28 PM
  2. eyestotheKING's Avatar
    Anything?
    12-01-2012 03:45 AM
  3. ThePurpleAndroid's Avatar
    You using a HTC? Do you have a restart option in your power off menu? It will shut down all running apps and reboot the phone. I use it when Friendcaster photo upload gets stuck like that. If not, try taking the battery out for a couple minutes.
    ~~HTC Evo Design~~
    PvilleComp and eyestotheKING like this.
    12-01-2012 04:45 AM
  4. PvilleComp's Avatar
    When all else fails... reboot the phone.
    eyestotheKING likes this.
    12-01-2012 04:24 PM
  5. eyestotheKING's Avatar
    My phone died the other day and when I restarted it, it was gone. Thanks for the replies!
    ThePurpleAndroid likes this.
    12-05-2012 06:32 PM
  1. text msg in notification bar and shows 1 on msg icon
    By dfb8085 in forum AT&T Galaxy S III
    Last Post: 07-10-2012, 02:01 PM
  2. font color on notification bar and keyboards
    By pmoneyprix in forum LG Optimus S
    Last Post: 05-22-2012, 11:14 AM
  3. Notification Bar and Soft Key Buttons Disappeared! Please help!!
    By YellowFlash9559 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 05-02-2012, 09:43 AM
  4. Replies: 9
    Last Post: 07-08-2011, 02:31 PM
  5. I want a Black Notification bar and....
    By Oj467 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 12-15-2010, 06:53 PM
