1. iDred's Avatar
    I bought these screen protectors and they come with no directions.
    3x Samsung Galaxy S Blaze 4G SGH-T769 (T-Mobile) Premium Invisible Clear LCD Screen Protector Kit (3 Piece Kit)
    Amazon.com: 3x Samsung Galaxy S Blaze 4G SGH-T769 (T-Mobile) Premium Invisible Clear LCD Screen Protector Kit (3 Piece Kit): Cell Phones & Accessories
    Basically the screen protector has two peices of plastic that you must peel away before applying. The reviews were mixed and I think they depended on the way you apply the screen protector.
    So my question is do I need to use water when applying them, or can I apply these dry?
    11-24-2012 05:49 PM
  2. B. Diddy's Avatar
    Try these instructions:
    Get all the help you need with our Screen Protector FAQs!
    11-24-2012 05:58 PM
  3. PvilleComp's Avatar
    If it is a shield that adheres by static, and it looks like it is, a little water won't hurt to help it cling.
    11-24-2012 05:59 PM
  4. B. Diddy's Avatar
    Also, this was posted in one of the reviews of your screen protector:
    "Instructions: The package didn't come with any instructions but it was intuitive because each protector had two tabs numbered [1] and [2]. These basically were attached to a very thin adhesive film (yes a protector for the screen protector) one on each side. I guessed (correctly as it turned out to be) that you need to peel film tab [1], place the protector on the phone, make sure it was installed properly, and then peel off film tab [2] as the last step.
    Installation: First, I made sure the phone's glass was clean of smudges, dust, or lint. I peeled of the protective layer numbered [1] and lined-up the bottom edge of the protector (adhesive side down) with the bottom part of the phone's screen. Then I just let the screen protector fall gently on the phone. Except for 2 or 3 button-sized air bubbles, the protector glued itself nicely to the screen without applying any pressure. Next, using the felt/microfiber cloth that was included in the package, I wiped the screen with gentle pressure to push the air bubbles to the edges and off the screen. I had to use my fingernail to push a couple of small stubborn bubbles close to the edge of the protector. Last, I peeled off film tab [2] from the top and wiped the protector again to remove smudges."
    11-24-2012 06:00 PM
  1. Do I need to use a screen protector with Gorilla Glass? (answer inside)
    By Cory Streater in forum Epic 4G Accessories
    Last Post: 11-08-2012, 03:39 AM
  2. What do I need to flash boot/shutdown animations with CWM?
    By W0lfy B in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 07-10-2012, 09:56 PM
  3. I used Unrevoked 3 to root my EVO still all stock do I need to remove to OTA to GB
    By drlib in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-02-2011, 02:56 PM
  4. People with no screen protector...what do you use to clean your screen?
    By dave9851 in forum Verizon Droid Incredible 2
    Last Post: 05-17-2011, 02:11 PM
  5. Do I need to use a screen protector with Gorilla Glass? (answer inside)
    By Cory Streater in forum Fascinate Accessories
    Last Post: 05-09-2011, 05:05 PM
