- 11-25-2012, 05:55 PM
Thread Author #1
Phone not downloading iPhone MMS messages or sending pictures
This is my first forum post, so I apologize if I am doing this incorrectly.
I own a T-Mobile Comet and have been able to download the iPhone MMS messages and send pictures before. I have owned this phone for roughly a year, and starting a couple weeks ago I have been unable to receive the MMS messages or send my pictures, I use Handcent. What happens when I get the message- It says Subject:no subject 1 KB and has a download button, after I press it all that happens is it says "Downloading" for hours on end and never actually does. When I send pictures the send spiral just spins endlessly and it doesn't send. My mobile data is on, my WiFi is off and I'm not sure what else I need to do.
Feel free to ask any questions, I'm more than happy to provide additional information as it is needed. Thank you for your time and help, have a great day! - 11-25-2012, 09:25 PM #2
Re: Phone not downloading iPhone MMS messages or sending pictures
Open the stock messaging app and see if the image is loaded. Also, try uninstalling Handcent and re-install it. If you received mms before there should be no reason for it not be received now unless there's a network problem or something in settings was changed.
Thanked by: - 11-26-2012, 06:38 PM
Thread Author #3
Just tried it, and it worked! My stock messaging app would download/send everything and then it would end up popping up in Handcent right after. So I reinstalled Handcent, and everything is working great. Thanks so much, I appreciate it
- 11-29-2012, 11:56 PM #4
Good question! Although T-Mobile cannot guarantee functionality of non T-Mobile phones, your MMS should work if you have a data plan (usually, you will need a Wi-Fi calling feature for MMS to work over Wi-Fi). You will need to input T-Mobile's data and mms network settings. If this doesn't fix it, you may want to check out some of the threads that are specific specific to the iOS. There are a variety of fixes, depending on how the phone is unlocked and the iOS.
Let me know if this helps! - 12-11-2012, 04:57 PM #5
i have the SAME problem with my samsung g3....i use go sms...ive tried even through regular stock messaging and still has issues! ugh! HELP
j~lyn
GO COWBOYS!!!
Phone not vibrating on text messages even if set to vibrate
By overkill#ac in forum AT&T CaptivateReplies: 3Last Post: 11-11-2012, 08:50 PM -
Cant recieve or send pictures via text? Generic network failure
By mel4iu in forum HTC EVO 4G LTEReplies: 4Last Post: 10-29-2012, 11:44 AM -
Phone not sending or receiving MMS
By .The Word Alive. in forum Sprint Motorola Photon QReplies: 3Last Post: 09-21-2012, 10:53 AM -
When phone flips to side when Messaging the Send becomes "Done"
By Centauri0 in forum Motorola Triumph on Virgin MobileReplies: 6Last Post: 07-20-2011, 08:48 PM
Reply
