Results 1 to 2 of 2
    dana25's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default i can't go into recovery or download mode after flashing bricked!
    Hi,
    could anyone help!
    my device is galaxy ace s5830i
    i have already rooted my device and used CW Recovery and taken a copy of my original system .oki
    i wanted to set up a custom rom i restarted and reset and deleted the cash then installed the rom.
    i think it was Retribution beta
    then i wanted to update to that custom rom (MindCR ICS)
    all i did i restarted my phone of course went into R mode and reset and deleted the cash then installed that next custom rom .
    after installing completed when i rebooted it only gave me (samsung galaxy ace s5830i) logo and doesn't open the system when i restart it doesn't go into recovery or download mode it only gives me again the same logo.
    i used odin v 1.81 and the latest version it doesn't recognize the phone and i can't go into download mode.
    is there any way or i say good bye to my handset!
  2. #2
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default Re: i can't go into recovery or download mode after flashing bricked!
    I would flash your original Recovery backup to get up and running again. Then try downloading the new ROM again and check the MD5 to make sure it's a good download. Sounds like you flashed a corrupt file.
  1. HELP!!!! Can't boot into Recover OR Download!
    By Matts8808 in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 11-08-2012, 09:04 AM
  2. Can't go into recovery mode and superuser denying all permissions!!! HELP!!! :(
    By hailsusy90 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-18-2012, 09:57 AM
  3. Can not go into emergency or recovery mode
    By glider12 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 08-18-2012, 04:18 AM
  4. In Download Mode After Flashing, How Long Should This Take?
    By theescapist99 in forum General Help and How To
    Last Post: 07-05-2012, 09:04 PM
  5. Can't get into recovery or download
    By b.roberts in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 12-24-2010, 06:39 PM
