Results 1 to 3 of 3
- 11-27-2012, 05:55 AM
Thread Author #1
Browse (and download) files from PC using my phone (via USB)
Does anyone know of a way to browse a PC directory structure using an android phone (Galaxy Note 2 in this case) and maybe download files directly to my SD card?
I have a laptop and the screen has gone - most of the info is backed up but there are a couple of documents I would like to try to salvage if possible.
Thanks - 11-27-2012, 08:50 AM #2
Re: Browse (and download) files from PC using my phone (via USB)
First off - couldn't you hook the laptop up to an external monitor? You should be able to this - do you have access to a monitor or projector?
Second - I don't know of any way to connect via USB and browse a PC without first having installed software on the PC such as TeamViewer or other remote access software. There are also ways you could do this if your phone and PC were on the same Wifi network with something like AirDroid, but this again would require you to open a browser window on the laptop and navigate to the appropriate IP address.
I think your best bet is to hook the laptop up to a monitor, projector or any TV manufacturered in the last decade. - 11-28-2012, 10:05 AM
Thread Author #3
how fast is transferring file from PC to Galaxy Nexus via Bluetooth connection?
By af250xxl in forum Verizon Galaxy NexusReplies: 2Last Post: 10-10-2012, 08:45 PM -
Help: I cannot transfer mp3 files from pc to my Xperia S
By inot1105 in forum Other Sony Android PhonesReplies: 2Last Post: 08-16-2012, 11:14 AM -
Windows not picking up my phone via USB connection...
By AnAm85 in forum T-Mobile VibrantReplies: 0Last Post: 10-07-2010, 09:05 PM -
Transferring files from PC to Android using Windows 98?!
By Destroid in forum General Help and How ToReplies: 9Last Post: 10-03-2010, 07:40 PM -
How do I sync my Outlook from PC to my phone?
By RGeise in forum General Help and How ToReplies: 3Last Post: 09-20-2010, 02:08 PM
Reply
