Hi I had my phone for about a month and it worked fine, but recently it seems to have started rapidly losing battery. I've attached a screen shot to show what I mean. Any suggestions on why and how to stop it?
Printable View
At first look, it seems like your biggest drops are occurring in low/no signal areas. You didn't mention what phone/carrier you are using, so I'll make an assumption it's an LTE device and the low signal area drops are the LTE radio frantically searching for a signal.
Also look at your app battery usage. It could also be a new app that's causing the drain.
There are so many possible explanations. One recent issue is Amazon Appstore, which apparently had a bug causing significant battery drain. If you haven't updated it recently, make sure you do so. It doesn't always update correctly from the Appstore's Settings menu, so it'd probably be easiest just to go to [Only registered and activated users can see links. Click Here To Register...] on your phone's browser, download the apk, and open it to start the install.
