1. Aaram Smith's Avatar
    Hi I had my phone for about a month and it worked fine, but recently it seems to have started rapidly losing battery. I've attached a screen shot to show what I mean. Any suggestions on why and how to stop it?
    11-28-2012 10:24 AM
  2. PvilleComp's Avatar
    At first look, it seems like your biggest drops are occurring in low/no signal areas. You didn't mention what phone/carrier you are using, so I'll make an assumption it's an LTE device and the low signal area drops are the LTE radio frantically searching for a signal.
    Also look at your app battery usage. It could also be a new app that's causing the drain.
    11-28-2012 08:39 PM
  3. B. Diddy's Avatar
    There are so many possible explanations. One recent issue is Amazon Appstore, which apparently had a bug causing significant battery drain. If you haven't updated it recently, make sure you do so. It doesn't always update correctly from the Appstore's Settings menu, so it'd probably be easiest just to go to Install Amazon Appstore on your phone's browser, download the apk, and open it to start the install.
    11-28-2012 10:49 PM
  1. A different type of Battery Issue
    By alexgtp in forum Verizon Droid Incredible
    Last Post: 05-22-2010, 04:07 PM
  2. Tried and true fix for battery issue
    By andyandroid in forum Verizon Droid Incredible
    Last Post: 05-19-2010, 02:00 PM
  3. Koush's Rom Battery Issues
    By tuxedojacob in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-04-2010, 10:59 AM
  4. Droid Restart/Battery Issue
    By Dapke36 in forum Motorola Droid
    Last Post: 02-09-2010, 11:40 AM
  5. Weird Battery Issue?
    By jacob.downey in forum Google / HTC Nexus One
    Last Post: 01-30-2010, 03:24 PM
