Results 1 to 3 of 3
    Question Trying to build an AutomateIt Pro rule... having some issues (screen off, recurring actions)
    I used to use Llama, but things got a bit wonky when it was starting Wifi back up (wifi would connect, then drop the connect and not re-establish) so I decided to give AutomateIt a poke... but the big rule I want is a rule that messes with my wifi/mobile data when the screen is off to help extend battery life. The rule needs to do this:
    1) screen goes off wait 5 seconds and disable wifi/mobile and sync
    2) Start a recurring rule that runs every 15 minutes (or whatever) that enables wifi/mobile, calls for a sync, the disables the wifi/mobile a minute later.
    The programmer in me would like to have this all done in 1 rule (which I could do in Llama)... The best I could come up with is two recurring rules that kick off when the screen goes off... 1 that disables data on screen off, then disables things every 15 minutes..2 that runs every 15 minutes and offset it by 14 minutes so it alwyas kicks off a minute before everything gets shut down again.
    Anyone have any thoughts as to how to get this in one uber-rule?
  2. #2
    Default Re: Trying to build an AutomateIt Pro rule... having some issues (screen off, recurring actions)
    You can't do that in one rule.
    What I would do to make it a bit cleaner is to reverse the rules you have defined:
    1. Turn Wifi/Mobile data on every 15 minutes
    2. Turn Wifi/Mobile data off every 15 minutes with 1 minute delayed execution
    Both rules will be enabled when screen is off (using a composite action of two Enable/Disable rule action) and disabled when screen is on.
    Doing it that way you gain a "one minute grace period" when you turn off your screen it was accidently turned off, and the countdown to turn off will be only 1 minute which I think is nicer.
    Look for AutomateIt on the Google Play store to Automate Your Android !
    Thanked by:
    LeoRex
    Yeah... I've been playing around with a method like that. Ran into some crazy run-away loops that hung up the app and froze the phone for a minute when I tried to do too many cute things.. but I think I have it nailed down. Thanks for the response!
  1. Trying to modify an existing rom
    By pandacookie in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 09-04-2011, 07:29 PM
  2. Trying to find an unusual app.
    By bigbdroid in forum Android Applications
    Last Post: 07-08-2011, 08:49 PM
  3. Replies: 5
    Last Post: 03-10-2011, 04:46 PM
  4. Replies: 3
    Last Post: 03-19-2010, 09:03 AM
  5. Trying to find an app that adds letters to scrollbar
    By austins in forum Motorola Droid
    Last Post: 01-06-2010, 02:23 PM
