Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By B. Diddy
    Default will vibrate on keypress use battery?
    will enabling vibrate on key press (when you hit a letter or anything it vibrates) drain or use any battery?
  2. #2
    Default Re: will vibrate on keypress use battery?
    Yes it will.
  3. #3
    Big time.
    i called my manufacturer and they said it wouldn't
  5. #5
    rexxman's Avatar
    Posts
    Global Posts
    188 Global Posts
    Why do you even ask this question and who was the mfg that told you it wouldn't?
    Sent from my SCH-I535 using Android Central Forums
    It was Huawei
  7. #7
    Look, everything you do on your device uses battery. Operating the vibrating mechanism is going to use more battery than, say, generating a sound when you press a key. And clearly, turning vibration off means you won't be using the battery to power the vibrating mechanism. So is it going to cause drastic battery drain if you keep it on? No. But if you're trying to squeeze every last drop of battery power out of your device, then turn off the vibration and the sound with keypress. I would also turn off vibration when the phone rings and vibration with notifications, if you're concerned about it.
    ahawkua likes this.
  1. Google Music vs Music on memory card - Battery use?
    By PaulQ in forum Verizon HTC Rezound
    Last Post: 04-09-2012, 04:03 AM
  2. How to charge battery properly on 1st use & is an adapter okay?
    By Alazarin in forum Samsung Galaxy S II
    Last Post: 11-03-2011, 11:25 AM
  3. Replies: 52
    Last Post: 07-13-2010, 03:27 PM
  4. Vibrate on screen touch, am I losing my mind?
    By mikedaub in forum Verizon Droid Incredible
    Last Post: 05-13-2010, 12:59 PM
  5. Vibrate on email/sms notification
    By TeethMummy in forum Verizon Droid Incredible
    Last Post: 05-07-2010, 04:06 PM
