1. Brandon Jacobs's Avatar
    The Nexus 4 is my first android phone I'm loving it so far!
    I have one question I haven't been able to find on Google. When I plug in the phone a black-and-white battery screen comes up and flashes showing the phone is charging, at least I think. I haven't waited to find out, I just end up turning the phone on every time.
    My question is, what is this charging mode and how does it work? It doesn't seem to charge any faster than the phone being on.
    11-28-2012 11:49 PM
  2. badbrad17's Avatar
    That is probably just an animated screen when you plug in. I think the Jellybean 4.2 OS has a bunch of screens that can play while you charge. Like a screen saver.
    Sent from my SGH-T989D using Android Central Forums
    11-29-2012 01:02 AM
  3. sropedia's Avatar
    If you plug your phone in when it's off, the screen is simply a conformation that its connected and charging, and gives you an idea of how much battery life it has without the need to turn your phone on. Hope that helps
    Sent from my HTC One X
    11-29-2012 01:07 AM
  1. Overheated battery - locked into charging mode?
    By mvowell in forum Barnes & Noble Nook Color
    Last Post: 01-25-2012, 06:33 PM
  2. Battery charging time insanely long?
    By dakis#AC in forum Google / HTC Nexus One
    Last Post: 01-24-2010, 08:38 AM
  3. Battery Charging question
    By grifforama in forum HTC Hero
    Last Post: 12-15-2009, 08:55 AM
  4. 2.0.1 and battery charging
    By roguephoenix#AC in forum Motorola Droid
    Last Post: 12-11-2009, 05:01 AM
  5. Eris Charging and Battery Charging Dock?
    By cjohnson481 in forum HTC Droid Eris
    Last Post: 11-15-2009, 06:49 PM
