- 11-29-2012, 08:31 PM
Thread Author #1
Help please!
Is there anyway to bounce the wifi from your phone to other devices. Like not tether over 3g but using the connected wifi on your phone and bounce it from your phone to like my Xbox. Because I can pick it up with my phone but not with my Xbox. Because its stronger on my phone. So I wondering if that was possible.
- 11-29-2012, 08:50 PM #2
Re: Help please!
You can make some of the newer devices into hotspots, but from what you are asking, it sounds like you want to use it as an access point where the phone is just a signal extender. Is that correct?
If your phone is receiving a wifi signal that is strong, i would have to say your xbox should be receiving the same signal strength if they are in the same area. Therefore, there may be something wrong with your xbox wifi that is interfering with the data speed. May just be a setting. If your NAT is not set to open on the xbox, that can slow it down a lot.
If you have the old cream xbox with a plug in wifi adapter, i would have to say that the adapter could be bad, or the software (drivers) could have issues. It is also a "G" connection, not an "N" like most newer devices. That alone is a difference in speed.
I also believe that if you use your phone as a hotspot, it uses the cell radio, not wifi. There are ways around this with rooting and the posts can be found here on this forum or over on xdadevelopers dot com.
Sent from my GT-N8013 using Android Central ForumsThanked by: - 12-08-2012, 03:43 PM
Thread Author #3
Yahoo mail email help please!!!!
By ciscocv84 in forum General Help and How ToReplies: 10Last Post: 12-12-2009, 12:58 PM -
Internet Not Working - Help Please?
By thezob101 in forum General Help and How ToReplies: 2Last Post: 10-30-2009, 09:03 PM -
help please
By aquaj13 in forum HTC HeroReplies: 7Last Post: 10-14-2009, 10:40 AM -
roadblock to getting started- help please
By theworldends in forum General Help and How ToReplies: 0Last Post: 07-13-2009, 03:13 AM -
need help please
By jfchica1987 in forum T-Mobile G1Replies: 1Last Post: 06-16-2009, 02:12 PM
Reply
