Is there any way to toggle the keyboard per use? Sometimes I want to use Swype, other times SwiftKey. The only way I can see how to switch is to change the default in settings.
I'm running ICS on a non-rooted Vivid.
Printable View
First off, you're literally the first person I've seen that would make use of a feature that I believe is standard in ICS.
When you tap a text entry box that pulls up the keyboard, you should see a keyboard icon in the notification bar. Pull the notification bar down and tap where it says "Select input method". That pops up a box for you to change inputs. As far as I know, you couldn't have turned that setting off. There was a lively thread recently on here debating if that was a feature or a bug, and if it could be disabled. It was established the shortcut was a feature that can't easily be deactivated.
Btw, I'm curious why you want this ability. No one in the other thread really had a good reason, and I've wondered what a good one would be.
I'm fickle? Because Swype works better with one hand and SwiftKey with two, so depending how I'm sitting, lying, propped up... (which may not make sense to anyone other than me, but there ya go...).
Thanks, your suggestion works. :)
thanks! i was looking for this answer too!
