Help! Accidentally uninstalled contacts storage .crashed now
Hello,
Im using a motorola photon rooted. Accidentally I
deleted contacts storage app. Now my dialer, contacts, every thing
Crashes.kindly help me with a solution. No backup taken until now.
System version : 45.4.13.MB855.SPRINT.EN.US
BUILT VERSION :45 4.5.1A_1_SUN_254_13
Android : 2.3.5
Re: Help! Accidentally uninstalled contacts storage .crashed now
I don't have your phone so I can't help but maybe someone can copy and upload it for you then just place it back in the folder you deleted from and reboot.
Also you can perhaps look for a system dump for your phone and take it from there
Good luck
From my Galaxy Note 2 via Tapatalk
Here's a link to the System dump - you should be able to get the file from there.
[Only registered and activated users can see links. Click Here To Register...]
