DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 6 of 6
    Default If I get a bigger android will typing be easier?
    Got optimus v now and 3.2" feels so small and hard to type compared to my 3gs which is only. .3" bigger.
    Thinking of HTC one, how y'all like that?
    Feels cramped and it hurts!
    Sent from my VM670 using Tapatalk 2
  2. #2
    Default Re: If I get a bigger android will typing be easier?
    Swype on Sony Xperia S with 4.0.4 is quite nice. Pretty huge screen, but at 720p it works out okay.
    Definitely a 4" screen is just nice for Android mobile phones, I think.
  3. #3
    Yes. It will be easier. I loved the HOX and my HOX+
    Sent from my HTC One X+ using Android Central Forums
  4. #4
    Of course it will be easier. I use the HTC One X this October and find typing be easier. I use the samsung s5830 before.
    Thanks guys
  6. #6
    Also you should try the new swift key Flow keyboard. It rocks once you get use to it
  1. If I use a BT mouse, will there be a "hover" feature?
    By dave1812dave in forum Google Nexus 7 Tablet
    Last Post: 10-15-2012, 10:03 PM
  2. Samsung / Android will always be better than Apple!
    By weston87 in forum Sprint Galaxy S3
    Last Post: 10-10-2012, 12:15 PM
  3. Will I be able to update to Android 2.3 if I root, recover, and ROM?
    By Tuskeste in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 01-31-2011, 11:29 PM
  4. Replies: 1
    Last Post: 06-10-2010, 06:06 PM
  5. Replies: 12
    Last Post: 06-08-2010, 03:36 PM
