1. chris mart's Avatar
    I used Titanium backup pro auto sync to dropbox option. Every time it shows "sync to drop box skip due to power/connectivity". When this scheduled activity run my battery level more than 85% and WiFi enabled. If I run this task manually it work without any issue. How do I fix this issue?
    Screen shot.
    12-03-2012 10:08 AM
  2. Matin Soroudi's Avatar
    Go to "Preferences/Dropbox Settings/History coverage" and Change it to "1 (single backup)" or "2"
    12-17-2012 07:42 PM
  1. Titanium Backup Pro Sync with Google Drive Issue
    By vicw926a4 in forum Android Apps
    Last Post: 09-23-2013, 08:04 PM
  2. Titanium Backup Pro - Drop Box
    By lartomar2002 in forum Android Apps
    Last Post: 04-04-2012, 09:14 PM
  3. Can a titanium backup restore auto-install apps to sd?
    By snipsta in forum General Help and How To
    Last Post: 08-30-2011, 09:45 AM
  4. titanium backup auto sync to dropbox
    By agula001 in forum Verizon HTC Thunderbolt
    Last Post: 07-09-2011, 04:58 PM
  5. Exchange RSS Feeds auto-sync to the Droid? Yep!
    By jgiddens in forum Motorola Droid
    Last Post: 11-18-2009, 09:03 AM
