Results 1 to 3 of 3
    Default HTC Volume button stuck in the down position
    My external button is stuck down, and when I press the power button to wake my phone up it thinks that I am pressing both at the same time. So the phone goes into the Hboot screen, where I cannot choose a function. (because the volume button is stuck down position.) I have to remove the battery and wait about an hour or so then re-insert the battery and pray that it loads up. What can I do to stop this from happening? Or is there a way to control the Hboot screen other than using the volume button?
  2. #2
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Carrier
    CM-7
    Default Re: HTC Volume button stuck in the down position
    Which phone do you have? It may be easy to loosen a screw or two and freeing the volume button, or even replacing it completely. I assume you have tried un-sticking it with a piece of paper or other slender object.
    I have the HTC Inspire 4g, and Yes I have tried everything including a q-tip with alcohol.
  1. HTC Hero (Sprint) stuck in "Safe Mode".
    By RickyBlack in forum General Help and How To
    Last Post: 02-24-2012, 12:31 PM
  2. Facebook messages stuck in the phones history
    By juniorvc17 in forum Verizon Droid Charge
    Last Post: 08-20-2011, 01:01 PM
  3. volume Button sits in more on the plus side
    By lovy in forum Verizon HTC Thunderbolt
    Last Post: 03-26-2011, 08:58 PM
  4. Stuck in the Muck
    By Ranji in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 03-07-2011, 06:55 PM
  5. Replies: 18
    Last Post: 06-19-2010, 03:37 PM
