Results 1 to 7 of 7
- 12-03-2012, 03:24 PM
Thread Author #1
Cyanogenmod and auto-syncing Google
Hi! I'm new to Android and I have some questions..
The easier one, how do I auto-sync google apps such as gmail and music? I'm on 4.2.
When I go to Settings > Scroll down to Accounts > Google, I see a small message saying "Sync is OFF". If I click on that I can manually sync, but I don't see any options for autosync.
Also, will getting Cyanogenmod benefit me since I already have 4.2? From my understading, Cyanogenmod is an alternative to the stock Android ROM, that lets users update to the newest firmware earlier than waiting for it to officially rol out for their device. Am I right on this? Or does Cyanogenmod do that plus add new features?
And if they do, what is an example of these features? I want to know if it is worth the root and voiding my warranty.
I know I've asked a lot but I would appreciate some help!
- 12-03-2012, 07:45 PM #2
Re: Cyanogenmod and auto-syncing Google
If you go into Google under Settings -> Accounts and then tap on your username it should bring up the list of Google features to sync.
As far as loading Cyanogenmod, that's up to you and what phone you have. Does Cyanogen support your phone directly? If so then it's a great ROM and I would highly recommend it (I run it as a daily driver on my phone.).Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 12-06-2012, 02:15 PM #3
- 02-28-2013, 08:17 AM #4
I have the very same problem. Somehow since I upgraded to CM 10.2 automatic sync is off. The big problem is I can't find out how to turn it back on again. There is no option in the Accounts section in Settings (some post on the net states that just go to "Settings" - "Accounts & Sync". But there is only "Settings" - "Accounts". There seems no way to enable sync here. Only to add account, remove accounts and manually start syncing
Guess the "missing Sync" might be because of the rather new "Profile" option. Inside here you can set if synchronizing is to be done. But it did not work. I also tried to disable "Profile" but that did not work either.
Its rather useless for me to have a phone where i have to synchronize manually! Please help. Am I missing something? - 05-09-2013, 01:52 PM #5
I had the same problem.
I succeeded to turn on notification by modifying setting inside the Gmail application. Once inside, click on your account name (On the left), and then check "Data Usage - SyncGmail" option. You should be presented with the (system) window that gives you an option to turn on synchronisation. - 05-11-2013, 12:58 AM #6
- 06-11-2013, 04:39 AM #7
same problem here: usually, there is a tick after every sync options, but now, the thick is disappeared.
I wipe whole system & data, and reinstall cm & google app pack, the tick is back, auto sync is no problem.
so I believe there must something damaged the "tick" thing.
anyone had any suggestion? thank you.
solution:
that's because I turned auto sync off. Turn that on, all ticks appeared, and sync works again.Last edited by 2anyone; 06-11-2013 at 05:07 AM.
Difference Between Background Data and Auto-Sync
By JonathanY in forum Virgin Mobile Optimus VReplies: 12Last Post: 01-01-2012, 12:44 AM -
Google Navigation, and Ford Sync
By ammarmon in forum Motorola Droid XReplies: 0Last Post: 01-20-2011, 08:30 PM -
Facebook and Auto-Sync
By stevenhglee#ac in forum Verizon Droid IncredibleReplies: 0Last Post: 08-26-2010, 12:53 PM -
difference between "background data" and "auto-sync"
By mattcnz in forum HTC EVO 4GReplies: 4Last Post: 06-15-2010, 12:01 AM -
Auto sync and battery life?
By DonnieAles in forum HTC EVO 4GReplies: 4Last Post: 06-07-2010, 05:11 AM
Reply
