Results 1 to 4 of 4
    Question Rooting?
    Hi all, quick question about rooting. If an app doesn't work when my phone is unrooted, will it work if I root my phone and then install it???
    Android!!!
  2. #2
    Default Re: Rooting?
    If it's an app that requires root
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    Thanks, but I didn't mean that. I have all ready had a look and I can't.
    Android!!!
  4. #4
    Quote Originally Posted by Pokemon3DS View Post
    It depends. the reason why many are not compatible is because they are not meant to run on those devices.
    If an app is compatible it doesnt matter if you are rooted or not. all works the same way. but there are some app which specifically need root for it to work.
    if an app is not compatible you can try to download if from other source and install it manually. most of the time it will work but not always.
  1. CDMA Hero rooted
    By Jerry Hildenbrand in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 01-22-2010, 08:47 PM
  2. Root on Sprint Hero, anyone?
    By ShiftNo in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 11-29-2009, 11:54 PM
  3. Root for the Eris - no go using current methods.
    By Jerry Hildenbrand in forum HTC Droid Eris Rooting, ROMs, and Hacking
    Last Post: 11-10-2009, 10:22 PM
  4. Rooting the Droid?
    By brandonscott in forum Motorola Droid
    Last Post: 11-06-2009, 08:43 PM
  5. How long to root and cooked roms?
    By tx26257 in forum Motorola Droid
    Last Post: 11-03-2009, 05:56 PM
