Results 1 to 8 of 8
- 12-05-2012, 11:11 PM
Thread Author #1
- 12-05-2012, 11:17 PM #2
Re: help my files are duplicated? dont know if its supposed to b this way!
Never seen this happen before unless u copied and pasted everything from a back up or something. Check a couple of folders and see the contents. If the content in the folder is exactly the same, get tah deleted all the duplicate folders buddy. Those thumbs are gonna get some exercise.
My GS3 sleeps in the bed and my girlfriend sleeps on the couch. - 12-06-2012, 12:16 AM #3
What device and which version of Android? If it's Jellybean, it might have to do with the multiple user profile feature, even if you don't have multiple profiles set up.
- 12-06-2012, 08:53 AM #4
- 12-06-2012, 10:49 AM
Thread Author #5
Its my tablet nexus 7 with the latest firmware. I don't have another user setup here also and if I did I don't think I would name my user "legacy" or "0". Kind of weird huh. So I'm not too sure if I should delete the duplicated files just yet. Anyone else's files look the same on jellybean?
- 12-06-2012, 11:24 AM #6
I see that too on my Nexus 7, and I don't have multiple users set up either. Maybe someone with more expertise can weigh in, but I'm guessing that the files aren't truly duplicated, and aren't taking up twice the space. The fact that the folder is labeled "emulated" suggests that it's more of a virtual folder system for the multiple profile feature. I wouldn't delete anything.
Sent from my Nexus 7 using Android Central Forums - 12-06-2012, 12:31 PM
Thread Author #7
- 12-16-2012, 04:45 PM #8
I have the same issue on my Nexus 7 when using Astro file manager, and also Office Suite Pro appears to 'see' the folders named '0' and 'emulated.' I am fairly confident that there is no actual duplication of files because I have about 9GB of music on the device and if this was duplicated it would not all fit!
ICS Update & Factory Reset - Now my files are missing! Help!
By DroidMomma30913 in forum Sprint Galaxy S II Epic 4G TouchReplies: 4Last Post: 09-22-2012, 05:35 PM -
have my charge dont know if im happy
By taylorz_412 in forum Verizon Droid ChargeReplies: 14Last Post: 08-28-2011, 05:39 PM -
Are the nookie froyo(Internal) icons supposed to be this small?
By PhyscoAssassinX in forum Barnes & Noble Nook ColorReplies: 6Last Post: 02-16-2011, 01:17 PM -
I dont know if my Htc Evo is Bricked or not
By shh218 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 7Last Post: 02-14-2011, 09:28 PM -
Camera acting funny. dont know if its froyo
By temotoren in forum HTC EVO 4GReplies: 4Last Post: 08-05-2010, 05:50 PM
Reply
