Results 1 to 3 of 3
    Opie33090's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Help! G2x locked on logo screen after installation of Cyanogen Mod.
    I never rooted my phone before and thought i would give it a try(SuperOneClick) and it went fine. Then I decided to use Clockwork to install a mod (cyanogen) and cleared everything i needed to, but after it reset it locked on the logo, the LG with a blue swipe behind it, and thats all i get. I tried putting it into APX mode, but my volume buttons wont respond. Any solution or am i bound to resort back to my Garminfone?......Which doesnt even run Gingerbread...........yea, that bad.
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Default Re: Help! G2x locked on logo screen after installation of Cyanogen Mod.
    you cleared all three caches?
    Can you get into recovery? if so maybe use a stock rooted rom to get it back to where it boots
    Opie33090's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yea, I followed the steps listed here about the subject and cleared all 3 listed and everything went fine until the reboot. When i hold Power + Volume -, I get the little android and box to signify the recovery, but then it jumps back to the LG logo.
  1. HELP!! Stuck on M screen after updating to .596
    By afp77 in forum Motorola Droid X
    Last Post: 06-20-2011, 10:15 PM
  2. Phone stuck on boot screen after I did nandroid
    By dannynyc in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-17-2011, 11:57 AM
  3. Eris Stuck on Boot Screen After Root
    By BlueMagicSS#AC in forum HTC Droid Eris
    Last Post: 01-03-2011, 01:25 AM
  4. Stuck on "M" screen after I did the OTA Froyo 2.2 Update
    By Blacker.the.berry in forum Motorola Droid
    Last Post: 08-26-2010, 02:29 AM
  5. Froze on "HTC" screen after flashing zips. (xda roms & zips)
    By DoubleA319 in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 06-02-2010, 11:41 PM
