I am an iPhone 5 convert with a new Nexus 4. I somehow in trying to learn things have deleted the stock clock app when i was only try to remove the home screen widget. How can I get the clock back?
Printable View
Deleted it entirely, or just from the lockscreen?
If you go into the App Drawer, is the Clock app still there?
It is not in the App Drawer, so entirely...:(
you cant delete a clock app unless you are rooted. do you mean you deleted it from home screen or app drawer?Quote:
Originally Posted by p1neapples [Only registered and activated users can see links. Click Here To Register...]
if its from home screen click the 6 dots on the centre and search for clock and touch and hold
or you might have disabled it. go to settings-->Apps-->All Apps-->[scroll all the way down]-->see if you have clock app there-->select it and click enable
In the App Drawer, make sure you're looking in the Widgets section. Tap Widgets at the top of the screen after bringing up the drawer.
Awesome - worked like a charm...Thanks!!
