Results 1 to 6 of 6
    p1neapples's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help - I deleted the clock on my Nexus 4
    I am an iPhone 5 convert with a new Nexus 4. I somehow in trying to learn things have deleted the stock clock app when i was only try to remove the home screen widget. How can I get the clock back?
  2. #2
    gone down south's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help - I deleted the clock on my Nexus 4
    Deleted it entirely, or just from the lockscreen?
    If you go into the App Drawer, is the Clock app still there?
    p1neapples's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is not in the App Drawer, so entirely...
  4. #4
    still1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by p1neapples View Post
    you cant delete a clock app unless you are rooted. do you mean you deleted it from home screen or app drawer?
    if its from home screen click the 6 dots on the centre and search for clock and touch and hold
    or you might have disabled it. go to settings-->Apps-->All Apps-->[scroll all the way down]-->see if you have clock app there-->select it and click enable
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    77,765 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    In the App Drawer, make sure you're looking in the Widgets section. Tap Widgets at the top of the screen after bringing up the drawer.
    p1neapples's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awesome - worked like a charm...Thanks!!
  1. I wiped everything on my NEXUS! please help
    By josequi in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 12-13-2012, 01:54 PM
  2. I need help restoring the kernel on my sprint Galaxy S3
    By dlx509 in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 10-18-2012, 12:13 PM
  3. Replies: 1
    Last Post: 01-17-2012, 12:19 AM
  4. Anyway to get the HTC Weather widget on my Nexus S?
    By geneticfusion in forum T-Mobile Nexus S
    Last Post: 01-30-2011, 09:28 PM
  5. Not delivered SMS on my nexus :(
    By sinister90 in forum Google / HTC Nexus One
    Last Post: 02-07-2010, 01:36 AM
