Need help please. Where do I insert the sd card on my virg mobile optimist LG android phone? I see some metal connectors under the battery near the bottom, but can't figure out where or how the card goes in the phone. Thank you.
Printable View
Which Optimus do you have? There are a bunch of them.
You can typically find the manual for your phone by doing a Google search. The manual can tell you where the SD card slot is. If you don't see an obvious door on your phone that opens up to reveal a slot, then it's probably behind the battery.
