Results 1 to 2 of 2
- 12-08-2012, 09:42 AM
Thread Author #1
- 12-08-2012, 10:22 AM #2
Re: Pearle Haymond
Which Optimus do you have? There are a bunch of them.
You can typically find the manual for your phone by doing a Google search. The manual can tell you where the SD card slot is. If you don't see an obvious door on your phone that opens up to reveal a slot, then it's probably behind the battery.
[FREE][ARCADE] Pearl Harbor Fury
By frankzxy in forum GamesReplies: 0Last Post: 09-02-2012, 05:33 PM -
[THEMES] GO SMS Pearl Themes
By stealthychief in forum Wallpapers, Ringtones, and ThemesReplies: 0Last Post: 04-11-2012, 06:15 PM -
Pearl Keyboard Skins
By stealthychief in forum Wallpapers, Ringtones, and ThemesReplies: 0Last Post: 09-14-2011, 08:39 PM -
Monster Turbine Headset - Pearl
By Stevez48 in forum Sold / Archived Marketplace ThreadsReplies: 1Last Post: 04-05-2011, 09:20 AM
Reply
