Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By natehoy
    Default Question about using phone without a cellular plan
    I'm about to replace my first Verizon LTE phone (ThunderBolt) with a Note 2. I would like to activate the Note 2 immediately and then take my time moving my data and apps off of the ThunderBolt. Am I correct in thinking that, once the ThunderBolt is replaced by the Note 2 from Verizon's perspective, I will still be able to use my ThunderBolt like I currently can except that I won't have cellular voice service (no phone calls or SMS) or cellular data (no 1X/3G/4G)? As long as I keep it on wifi, then my apps will sync and perform normally, correct? Just want to confirm before I make the switch.
    Also, what happens with the LTE SIM card? Do I move it to the new phone or do I get a new card with the new phone? Does not having a SIM card in the phone affect anything other than cellular voice and data?
    Thanks for the input!
    My tech timeline: 1981 - First programmed. 1986 - First modem connection. 1993 - First Internet SLIP account. 2000 - First broadband connection. 2003 - First BlackBerry. 2011 - First Android.
  2. #2
    natehoy's Avatar
    Posts
    ROM
    Stock
    Default Re: Question about using phone without a cellular plan
    Yes, the bolt should simply stop working on Verizon's network. Wi-Fi should continue to work fine. Basically, you'll have a very small android tablet.
    Thanked by:
    badbrad17 likes this.
    That's great to know. Thank you! I did just try booting it up without a SIM card. Wifi worked find but it gave several warnings, including this on the lock screen:
    "A SIM card is needed to operate this phone (Emergency calls only). Please turn off your phone and insert your SIM card."
    So I'm hopping I get to keep the old SIM card if for no other reason than to quiet those warnings down.
    Picked up my Note 2 yesterday evening. And, yes, I got a new SIM card with it so my ThunderBolt was able to keep its card and is now chugging away happily as a wifi-only device. It turns out that getting a new SIM card was a must in my case. The Verizon sales rep's system popped up a warning during initial setup that my ThunderBolt's SIM card was incompatible with the Note 2. So I'm happy. Now to figure out how to get the most out of this monster.
  5. #5
    You don't need the SIM to use the old phone. Ignore the warning.
  1. question about using phones and tablets on 3 & 4 g
    By dewmik in forum General Help and How To
    Last Post: 07-20-2012, 07:16 AM
  2. Couple questions about using the phone in Germany.
    By Goneeuro in forum AT&T Samsung Infuse
    Last Post: 08-04-2011, 08:34 AM
  3. Question about lost phone app (Lookout Plan B)
    By thompson.1372 in forum Verizon Droid Incredible 2
    Last Post: 07-24-2011, 01:09 PM
  4. Question about syncing phone to car
    By anicholas7 in forum Verizon Droid Incredible
    Last Post: 09-12-2010, 04:13 PM
  5. Question about switching phones...
    By mobilemedic20 in forum Motorola Droid
    Last Post: 03-01-2010, 02:23 PM
