Results 1 to 4 of 4
- 12-08-2012, 09:50 PM
Thread Author #1
- 12-08-2012, 11:12 PM #2
Re: problem connecting tablet to router
Is it that your tablet sees the router but can't connect, or does it not even see the router (i.e., does the router name not even show up in your list under Settings/Wireless & Networks/Wifi when your tablet's wifi is on)?
First thing to try is to reboot your router--unplug it, wait for 10 seconds, then plug it back in again. - 12-09-2012, 07:04 AM
Thread Author #3
It sees the router and allows me to enter the password then tries to connect, but doesn't. Then it shows the status for the router as "saved, secured with wpa/wpa2". Already rebooted the router and the tablet including a hard reset on the router.
- 12-09-2012, 08:57 AM #4
Try entering the password on the back of the modem if you have a modem that acts like a router. Verizon fios modems don't require u to have a wireless router so if you have one of those, just enter the password from that and not the wireless router. Disable all connections on the tablet, wait a few seconds and then enable them again. As this will refresh the connections and possibly you'll have better luck. Only thing I can think of. Make sure you're not messing up the password too. I know it sounds dumb but we all make a lil mistake sometimes. Good luck buddy
My GS3 sleeps in the bed and I make my girlfriend sleep on the couch
Problem connecting Safari to Internet
By Antarqui in forum Sprint Galaxy NexusReplies: 3Last Post: 09-12-2012, 08:44 AM -
Problem connecting to SDK/DDMS tool
By Lyanheart in forum AT&T CaptivateReplies: 1Last Post: 03-06-2012, 05:08 PM -
HELP with connecting tablet to TV using hdmi
By sugarshane810 in forum ASUS EeePad TransformerReplies: 4Last Post: 01-16-2012, 04:18 PM -
is this a typical.wifi problem? connects to network but no connectivity.
By jcochranusn in forum Motorola Droid XReplies: 9Last Post: 09-24-2010, 04:49 PM -
problem connecting to secure (https) sites
By doctorg23 in forum Verizon Droid IncredibleReplies: 0Last Post: 07-26-2010, 04:49 PM
Reply
