Results 1 to 2 of 2
    Default Replaced framework-res.apk = bootloop [LG DoublePlay]
    Hey guys!
    I modified and replaced the original framework-res.apk on my LG DoublePlay (C729) and now it keeps bootlooping on T-Mobile logo. Even the recovery mode didn't help - the recovery mode displays only an unpacking icon and then it reboots the phone. I have the original framework-res.apk but I'm not able to get it into my phone. USB connection with PC is stable. Any help would be greatly appreciated.
    Thank you!
  2. #2
    Default Re: Replaced framework-res.apk = bootloop [LG DoublePlay]
    Loaded lg software and reset to factory original
    You will loose your data but will get you back up and running it's been a lifesaver
    Sent from my LG-MS840 using Android Central Forums
  1. Framework-res.apk utility
    By Chris3D in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 07-06-2012, 08:37 AM
  2. Where is framework-res.apk in LG Optimus V?
    By ARP in forum Virgin Mobile Optimus V
    Last Post: 02-12-2011, 09:12 PM
  3. Editing framework-res.apk questions..
    By sniffs in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 12-30-2010, 09:58 AM
  4. Stock framework-res.apk and services.jar
    By notoriouslyKEN in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 09-21-2010, 12:35 PM
  5. Modify framework-res.apk without rooting?
    By xIcarus in forum Software Development and Hacking
    Last Post: 06-20-2010, 01:55 AM
