Need help on how to prevent files from saving onto my sd card, without un mounting it.
Sent from my Note II on steroids
Printable View
In what circumstance (s)? I've found that most apps have an option in the preferences to determine where things are saved.
Personally though, given that apps can only be installed to the internal memory, I have everything save to the sd card.
Sent from my SCH-R950 using Tapatalk 2
When I download files from the browser it doesn't let me choose where to save it, just auto saves to sd, and I don't want to unmount card just to save to device
While in the browser:
Menu button > Settings > Advanced > Default Storage
As with most apps, it's in the settings.
Just tried it and works like a charm, thanks a bunch! :cool:
