Results 1 to 5 of 5
    moralcode's Avatar
    Posts
    Global Posts
    101 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note II-SD card, how to change file destination?
    Need help on how to prevent files from saving onto my sd card, without un mounting it.
    Sent from my Note II on steroids
  2. #2
    Jennings Richmond's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note II-SD card, how to change file destination?
    In what circumstance (s)? I've found that most apps have an option in the preferences to determine where things are saved.
    Personally though, given that apps can only be installed to the internal memory, I have everything save to the sd card.
    Sent from my SCH-R950 using Tapatalk 2
    moralcode's Avatar
    Posts
    Global Posts
    101 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I download files from the browser it doesn't let me choose where to save it, just auto saves to sd, and I don't want to unmount card just to save to device
  4. #4
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    While in the browser:
    Menu button > Settings > Advanced > Default Storage
    As with most apps, it's in the settings.
    moralcode likes this.
    moralcode's Avatar
    Posts
    Global Posts
    101 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just tried it and works like a charm, thanks a bunch!
  1. Note II sd card read speeds
    By punchfacejay in forum Samsung Galaxy Note 2
    Last Post: 03-16-2013, 01:30 PM
  2. Swapping SD cards.. how to move content?
    By flynlow in forum Sprint Epic 4G
    Last Post: 08-25-2011, 06:59 PM
  3. CM7 now on SD card... How do I move files to same SD?
    By Legobricke in forum Barnes & Noble Nook Color
    Last Post: 05-13-2011, 07:56 AM
  4. How to Save file to SD card
    By lsdspikedudley in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 04-05-2011, 10:08 AM
  5. How to move files to SD Card
    By dsmith1069 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 10-30-2010, 03:50 PM
