Results 1 to 2 of 2
    Angry HELP! Playlist songs stop working afte a while
    I'm running a new galaxy s2 and am running into a major problem with the playlists I'm creating. After I create a new playlist and spend time putting songs in them they work for a while untill, usually overnight when I try and play them again the song stays at 0 seconds and will not play. I havent found any other forums addressing this problem and I'm going crazy trying to fix it especially since in my trouble shooting i cant seem to find one thing that makes it happen. Its not certain songs or certain playlist. The songs work fine untill for some reason they wont play anymore. My phone recongnizes them and the same song will play if I play it through the normal route (Atrists or albums) but when i play it from a playlist it wont play if anyone can help me please respond. Also i am running this music from an sd card and this is a new problem and it happens with all the music players i try. I was on winamp and then i moved to player pro because i thought the problem was with winamp but its happening with player pro to.
  2. #2
    Default Re: HELP! Playlist songs stop working afte a while
    I was having this same issue. Check the settings in the players. If you see "auto rescan" checked, uncheck the box.
    Sent from my Unrooted Droid Razr Maxx Using Tapatalk
  1. Keypad stops working while in a call
    By dpham00 in forum Verizon HTC Rezound
    Last Post: 01-20-2012, 02:55 PM
  2. Data stops working after a while
    By unixpsycho in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-05-2011, 11:51 AM
  3. Help!! External Speaker stopped working
    By TonyRage in forum T-Mobile G1
    Last Post: 02-10-2010, 06:12 PM
  4. Reboot, Eris stops working (A Dare!)
    By IzelTokatl in forum HTC Droid Eris
    Last Post: 01-08-2010, 02:22 PM
  5. Yahoo Mail - Stopped Working?
    Last Post: 12-18-2009, 12:32 PM
