Results 1 to 3 of 3
    Default Galaxy S3 Battery
    So this morning I wasn't really doing anything important, a few phone calls, and my phone is 60 percent dead.
    So what does everyone use to monitor their battery use? Is there an app that will tell me what has been killing my battery all morning?
    Thanks much.
    Sent from my SCH-I535 using Android Central Forums
  2. #2
    Default Re: Galaxy S3 Battery
    Try to use Easy Battery Saver to help you, which can use to Save power, extend battery life and perfect experience of using phone!
    You can download the app here:
    Thanked by:
  3. #3
    I was having similar power issues and posted about it last week. Someone recommended Android Booster. I love it. You can really throttle down your smart phone for your basic text and talk. Then, when you need it, just press a button and let the horses run. It will also tell you what is draining the battery...even though you can get a basic view of it by visiting the battery and section of the settings menu.
    This app can also be found on the Google Play Store.
    Also make sure that your "Smart Stay" isn't stuck in the on position permanently. I had that happen to me. Look for the eye icon in your notifications bar. If it is, just turn the feature off.
  1. Galaxy S3 Battery life
    By Hellfire7 in forum Samsung Galaxy S3
    Last Post: 04-08-2013, 08:12 AM
  2. Galaxy S3 Battery ?
    By cea1203 in forum Verizon Galaxy S3
    Last Post: 03-06-2013, 10:18 AM
  3. Samsung Galaxy s3 battery issues
    By philip111 in forum Samsung Galaxy S3
    Last Post: 12-01-2012, 02:07 PM
  4. Samsung Galaxy S3 battery issue.
    By beachprance in forum Samsung Galaxy S3
    Last Post: 10-12-2012, 08:56 AM
  5. Samsung Galaxy S3 Battery Cover - Metal
    By D2VW14_20 in forum Sold / Archived Marketplace Threads
    Last Post: 08-11-2012, 09:22 PM
