Results 1 to 4 of 4
- 12-18-2012, 01:06 AM
Thread Author #1
- 12-18-2012, 01:13 AM #2
Re: does adw launcher use more battery?
All depends on what you have ADW Launcher doing... Added animations, etc. that are above the normal launcher then yes its working harder and eating more battery. I still don't think it will be enough to really worry about in battery life.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 12-18-2012, 09:47 AM #3
I use it by default and its a great launcher with no battery issues whatsoever. The only way you'll know if it eats your battery is to give it a try. At worst, you'll just end up not using it and go back with stock or whatever you're using.
- 12-19-2012, 08:51 AM #4
I've used ADW and Nova. There hasn't been any noticeable impact to battery life using either.
does handcent sms use more battery than stock messaging app?
By ahawkua in forum General Help and How ToReplies: 2Last Post: 12-13-2012, 08:52 PM -
Do non stock launchers use more battery
By stephanie85 in forum Sprint Galaxy S II Epic 4G TouchReplies: 5Last Post: 10-20-2011, 07:22 PM -
2.2 visual changes, use more battery?
By gbororats in forum Motorola Droid XReplies: 1Last Post: 09-23-2010, 05:22 PM -
phone uses more battery then it charges?
By murso74 in forum Sprint Epic 4GReplies: 4Last Post: 09-06-2010, 06:22 PM -
Dolphin browser using more battery than standard browser
By Jetster220 in forum Android ApplicationsReplies: 6Last Post: 12-09-2009, 12:52 PM
Reply
